what does the +1 mean on the cam degree
i found a cam i wanted to put in my 99 SS and am confused on what the degree in a 114 differ from a 113+1 ?
the nitrous cam specs are 228/236, 0.551/0.600, 114
and the custom cam i found is 224/228 .590"/.595" 113+1 Custom Camshaft
which would give me more performance and have a nice sound to it
the nitrous cam is a crane cams scoggin dickeys custon n228 camshaft
and the other is a Shop custom cam i found on ebay that claim 50 hp gains over stock cam
New In The Box Camshaft Ready To Install 50+hp gains!
i have my motor torn apart and am trying to decide on a cam that will put me over 400 rwhp with supporting mods
i bought a lingenfelter weiand intake polished and an 80 mm throttle body
and some ported 243 heads with lunati voodoo 600. lift beehive style springs
The +1 is the amount of lobe advance that is ground into the cam. You can get the same results as a +1 by just taking a +0 cam and installing it in the motor with 1 degree of advance.
The advance means that the valves will open and close sooner which typically in theory results in a slight increase in low-mid range power and a reduction of high end power compared to a +0 cam.
cool
cool which cam would see better numbers with i know the intake and exhaust are bigger in the nitrous cam but the lift is sligthly greater in the ebay" cam that has the 113+1
freakin awesome
now that i learned a little more with the +1 i think that would be the perfect cam around what i am looking for thanks man i will most definately talk to them about that cam just need to find a scogg vendor for a price on that cam
LS1TECH & Trucks Sponsor
I can help you with whatever you need to know
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
