car doesn't want to stop at high speeds
For the past year or so the car has not stopped very well on high speeds. Like at drag strips and stuff-- 110 and up mph. You have to stand on the brakes real hard and it does not seem to want to do anything. Finally the brake pedal kind of pops down and then starts to brake better. Has anybody every heard of this? I have put WS6 store drilled and slotted rotors, Hawk pads and completely flushed the brake fluid with dot 4. Please let me know.
LS1TECH Sponsor
Something is sticking if you get a pop and then is stops better. You need to go through the hardware and slides. Something is mechanically wrong.
__________________
The front calipers, brackets and slide pins are all new in the front. When I did the brakes in the rear I greased the rear slide pins which seemed to move freely. I guess I will check the rear calipers. Let me know if you guys have any more ideas.
