axle help needed
Old 11-04-2008, 06:34 PM
99FormulaM6's Avatar
Default axle help needed
I need a set of axles for my Strange 12 bolt.
The car is a 4ch car, but the rear is not (a barebones business only rear basically). It has 33 spline axles and 3.73 gears which are 3 series.
I want ABS and TC back, and I have the backing plates but apparently my current axles wont work since the backing plates cant be pressed onto them. So, what axles do I need, and where can I get them from - or can my current axles be made to work?
Thanks
Old 11-04-2008, 11:34 PM
LS1Tech Premium Sponsor
ssvert99's Avatar
pull the axles out and send them to Strange along with your backing plates. they can machine the axles to accept the 4 channel rings and install your backing plates with new bearings and reluctor wheels if needed. you will need to call them first for a RMA number and prices. 847-663-1701
Old 11-05-2008, 06:14 AM
Only problem with that is down time. I recently started driving the car to work and need to keeo down time to a minimum
Old 11-06-2008, 06:52 AM
bump.
Old 11-10-2008, 06:53 PM
wht01ws6ta's Avatar
I was trying to do the same thing but with 9 inch axles. I was trying to minimize down time as well by going to a local machine shop but they estimated close to 200 and couldn't do it right away either. I ended up buying new axles from Speed Inc for just under 300 but also had to buy a bearing kit for 100 and will have to get the bearings pressed on as well. So I am trying to sell my original axles to recoup some of the money. Did you call Strange to see how much they charged (with shipping) and how long of a turn-around time it would be?
