tr-55 to tr6 to tr-7
ok i have a 150 wet shot and meth injection. i currently run tr6's but was considering going to a tr7. would i lose noticable n/a horsepower going colder again. i had trouble feeling any difference when i went to the tr6 from the 55's when i had spray. just curious.
you really need to read your plugs to get the proper heat range. it all depends on how much compression you have, how much timing you have, what gas you run and how big a shot. you cant just say x plug is good for y shot of juice. when you read your plugs you need to do a pull on the jug and shut the car down, if you idle or drive it afterwards it will mess up your reading. pull the plug and see what it wants. then you will know......
ps. bongva, ive sprayed a 175 on a tr55. tho i wouldnt recomend doing it often. you can spray a 75 on anything and get away with it. i think my weed eater will handle that. haha
