1344 u joints??????????
Old 11-05-2008, 04:01 PM
Z28M6TT's Avatar
Exclamation 1344 u joints??????????
is the 1344 the stock joint front and back for a 2002 M6 camaro???
summit says its a 1344, but others say its a 1310. i want to order new spicer u-joints for a STOCK driveshaft and STOCK rearend.
any help is greatly appreciated!!!
Old 11-05-2008, 08:02 PM
LS1Tech Sponsor
Scott@DrivelineSolutions's Avatar
Mechanics 1345 series the the ever so common GM inside snap ring u-joint. The 1310 series is an outside snap ring and is smaller all the way around.
Old 11-05-2008, 11:27 PM
Z28M6TT's Avatar
are 1310's weaker?
Old 11-08-2008, 05:53 PM
Kevin97ss's Avatar
Originally Posted by Z28M6TT
are 1310's weaker?
I once found a sheer chart listing all the different u-joints made, the 1310 is weaker. The stock joint in a steel shaft is near equall to the 1330 joint in sheer strength.
There were 3 different driveshafts available from the factory,steel LT1,alum 1LE and alum LS1. The 1LE is the only shaft that uses 1310 joints.
Quick Reply: 1344 u joints??????????
