does it make a difference?
Old 11-06-2008, 01:12 AM
extremetoy's Avatar
Default does it make a difference?
would it make a difference when building a motor looking for a certain compression ratio to build it with using dished pistons and low cc chamber heads, flat pistons and high cc chamber heads or a bit of both?
does it make any difference in performance/ reliability/ etc?
thanks, Gary
Old 11-06-2008, 01:49 AM
fast01's Avatar
Generally, a dished piston and small chamber will be the most efficient set up in a wedge type motor, with flat tops being the second best choice. The dished piston provides an unobstructed path for the flame front to propagate and more closely (somewhat) resembles a hemispherical chamber (the most efficient design). I'm not sure of the actual performance difference, but I would imagine that it would help with detonaton resistance. I hope this helps and if anyone else has anything to add to or argue this point, please do!
Oh yeah, dished pistons are usually a little lighter which is always good!
Old 11-06-2008, 02:25 AM
tomz28's Avatar
i have the same ??? anyone else with some info to share
Old 11-06-2008, 08:01 AM
Dumb Ass Vette Moderator
ls1290's Avatar
fast01 hit the nail on the head
Quick Reply: does it make a difference?
