HELP!! how to get rid of haze on my chrome wheels!?!?
Well on my chrome wheels there are some spots that are hazy and dont shine as much as the chrome should. Also if you look in the pics closely you can see that its kinda brownish in color and there are some brown spots around the wheel and if someone sprayed something on the wheel and left it on? Anyways i've been using everything! mothers chrome cleaner, mequiars cleaner, glass cleaner, acid wash the wheels (wheels were cold,not hot), super fine #0000 steel wool but the more i do it seems to get worse???
Im trying to get it back to that chrome finish guys but nothing seems to work. I know somebody had to bring back there chrome wheels from life. ANY INPUT is appreciated. thanks
here are the pics:
You can see on the left side half of the wheel where it is brownish/hazy in color and the right side has no problems
closer pic of the area:
here are the pics:
Well...since you've tried almost everything. Did you talk to FOOSE and see what they say? They may hold an answer or suggestion, that is their rims...so they should be able to give you some kind of answer.
Either way i still tried everything and nothing has worked. I could give FOOSE a call and see what they recommend.
