question about fast 92mm intake on a stock bottom end heads and cam ls1
I just sent the payment off on a fast 92mm intake. I was wondering if it will be to much intake for my set up. I will be using the prc stage 2.5 5.3 heads unmilled probably with the torquer v.3 camshaft from Texas speed. The car already has 1 3/4 coated pacesetter headers. I plan on adding a 25% under drive pulley and a set of 30lb red top injectors which will be more like a 36lb injector in a ls1. I also already have a circle d 3800 stall to go in the car. I am not to much worried about peak hp I would rather the car make hp where it counts and run well at the track. I am not looking to build a dyno queen as the car is an automatic.
I believe TSP had a FAST 92mm on their "MS4 Monster" that ran 9.82 on a stock bottom end.
i think the FAST would be a good match and like TVWilkes said will do great at the track.
PRC 215cc cylinder heads i believe thay should be available for sale by christmas
heres one thread on thier car
https://ls1tech.com/forums/single-digit-club/1004072-9-82-134-mph-stock-5-7l-346ci-ls1-short-block.html
or this thread
https://ls1tech.com/forums/multimedia-exchange/1002128-texas-speed-record-setting-9-82-heads-cam-video.html
cant wait til XMAS
or this thread
cant wait til XMAS
