Pushrod Question
Old 11-07-2008, 11:17 AM
RaM AiR 97's Avatar
Default Pushrod Question
If i am going to swap out RRs 1.6 on an all stock formula i dont have to change springs but push rods can they remain the same. Do i need a diffrent length??
Old 11-07-2008, 11:58 AM
lt1-xjs's Avatar
You need to change the springs, the pushrods remain the same.
Old 11-07-2008, 12:14 PM
Elliott's94Z's Avatar
Do it right the first time since you will be in there. I would get these items as well.
Comp Cam springs 26918-16
Comp Cam Valve spring retainers 795-16
Comp Cam valve locks 611-16
Comp Cam valve spring seats 4705-16
Comp Cam rocker arm studs 4505-16
Push rods I would get a set of Trickflow
Quick Reply: Pushrod Question
