Piston to valve clearance
Old 11-07-2008, 02:55 PM
Project382's Avatar
Default Piston to valve clearance
I am going to use a ls1 block 3.905" bore, Mahle flat top pistons with -4cc valve reliefs & 5.3 heads (706 head castings) i planned on running the chambers down to 59cc's and wanted to run a TR T-Rex cam. Anyone know if I would have piston to valve issues?
Old 11-07-2008, 03:21 PM
5.3LJimmy's Avatar
The 4cc pistons will have more than adequate clearance for that setup. Some 0.040 cometics would be a nice addition as well.
Old 11-08-2008, 12:21 AM
JPH
JPH's Avatar
Your good. But check anyways for good measure though.
Old 11-09-2008, 12:43 PM
Project382's Avatar
What do you think about increasing vave size to a 2.02? will I see PTV clearance then or should I stick with the stock 5.3's valves?
Old 11-09-2008, 01:00 PM
JPH
JPH's Avatar
You still should have plenty of depth and radial clearance with the 2.02 also.
Old 11-10-2008, 11:51 AM
Project382's Avatar
Cool! Thx guys!
