relocation brackets w/stock lca?
Old 11-12-2008, 09:58 AM
fly pantera's Avatar
Default relocation brackets w/stock lca?
will stock 02 lower control arms fit on a 99 ss with a moser 9" that has relocation brackets.
Old 11-12-2008, 10:08 AM
UMI Performance's Avatar
Yes they will fit
If the rear end sits off centered once you install it you may need to look into adjustable control arms to center it. The stock control arms will work but in most cases the 9" requires adjustable lower control arms to center it to prevent tire rubbing and for the springs to sit properly.
If you have any questions please let me know and I will be glad to help.
Thank you!
Ryan
Old 11-12-2008, 10:32 AM
thanks for the fast response.
im trasfering parts from my 99ss to my 02z28.reason being the ss is goin up for sale.the ss has adjustable lca,that will be moving to the z.now all i need is relocation brackets for the z,that will be umi.
Old 11-12-2008, 10:50 AM
Glad I could help and that sounds great!
Ryan
Quick Reply: relocation brackets w/stock lca?
