2002 Camaro SS 10 bolt rear with 6,000 miles! $400.00
We swapped out the rear in a low mileage Camaro SS for a Moser 9 inch when we did a complete build for a customer. This low mileage rear is in perfect condition, still has the bar code tag on it, and is a 3 channel rear. The car is an automatic and the gear ratio is a 3.23. Bob
Bump.
Bob, on a side note: how much would it be to get a set of 3.73 gears installed at your place on a factory 10bolt?
I need to get up to Ft.Wayne and have you guys put some subframes on (BMR); figured might as well get gears while the car is on the lift. GM Motives would be fine.
Thx. PM me if you want.
Bump.
We do not like to install gears in the 10 bolt rears. They can leave perfectly quiet and a week later the customer calls because his rear got noisy, and they think it is something wrong with the install. You have to charge enough to cover all the down time that you will have on the notoriously weak 10 bolt rears. If you don't, you want cover your cost. Bob
