Help new pcm and coil still throwing p0357
I need help with this one.
Mechanic did not want to do a compression test.
It seems to run great.
Any ideas why i still have this code?
Made it about 249 miles on new pcm, today it came back.
Thanks
Thanks
http://gearchatter.com/viewtopic9018...8d51867f9e8370
Your mechanic is at least smart enough to know a compression test is a waste of time. This is a circuit code. In addition to the coil and PCM you have all the wiring and connectors in the circuit. I'd try looking at the connectors real close first. The female pins have a bad habit of opening up.
