Fuel rail recommendation.
Kleeborp the Moderator™
If you go aftermarket, use a fuel rail that has provisions for o-ring bosses on the ends instead of pipe thread. Two off the top of my head that use o-ring fittings on the ends are Aeromotive and FAST.
I do not like pipe threads, especially on an aluminum part with fuel going through it.
If you don't need multiple plumbing options, stock fuel rails really can't be beat. I sold my old set to a guy on here a while back for dirt cheap.
is it possible to get these anodized blue? do you have that capability...? These are larger volume than stock right? they aren't like stock copies or anything correct...?
