Door locks help please
My automatic door locks stopped working from both the door switch and remote. There is a clicking over by the pass door. I am not even sure which fuse to check so help there to start would be great.
Ungrounded Moderator
The power locks aren't directly fused. They are controlled by the Body Control Module (BCM) which is protected by the COURTESY fuse. But if that fuse was blown you'd notice a lot of other symptoms such as no coutesy lights. The BCM is mounted behind the glovebox so that is likely the source of the clicking noise. It may also be the source of your lock problem.
