Rear springs rubbing?
Old 11-28-2008, 02:27 PM
nasty_ss's Avatar
Default Rear springs rubbing?
so the other day i was out driving and hit a bump while spinning the tires and now both rear springs are rubbing. how can i fix this?
Old 11-28-2008, 07:35 PM
TAtoad's Avatar
i would say the springs jerked around and arent sitting right. jack up the car, drop the rear end a bit and try to sit them in the way they should be. or maybe just get under there and beat them with a rubber mallet back into place.
Old 11-28-2008, 09:11 PM
nasty_ss's Avatar
thanks for the advice. i've already tried the mallet but haven't dropped the rear so i'll do that. i have a moser 12bolt in the rear could that have anything to do with it?
Old 11-29-2008, 11:34 PM
nasty_ss's Avatar
i'm pretty sure i bent the torque arm because both rear lower spring perches are leaning back and no longer level with the ground
Old 11-30-2008, 01:11 AM
TAtoad's Avatar
it must of been a good jolt to bend the torque arm. sorry to hear that
