stock line ????
Old 12-01-2008, 11:37 AM
tomz28's Avatar
Default stock line ????
how much power can stock line feed?????
i have twin 255lph pumps intank and a APS twin turbo camaro. the car has FAST fuel rails with a -6 line coming off the stock line under the hood. i run 60lbs injectors when will i have to upgrade the FPR and a return set up?
thanks
Old 12-01-2008, 11:48 AM
Nasty N8's Avatar
I have seen 700-750 with dual pumps and stock line.
Nate
Old 12-01-2008, 12:11 PM
tomz28's Avatar
do you think it could make more with with them
Old 12-01-2008, 06:49 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
You could with a front mount regulator & return line, but you are pushing things at 750 if you want stable fuel pressure. With a stock rear mount regulator, pressure will start to drop drastically.
Old 12-02-2008, 01:37 PM
tomz28's Avatar
all right
Old 12-02-2008, 07:33 PM
qqwqeqwrqwqtq's Avatar
thanks
We have used the stock feed line at 1100+rwhp in conjunction with dual pumps/upgraded rails/regulator.
Old 12-03-2008, 06:00 AM
tomz28's Avatar
wow any details on that setup
i have 2 255 right now can i take those out and put in 340s or bigger
