what should i get done to the heads
im running a 216 / 220 .525 / .532 114 LSA cam and i am wondering what you guys think would be the best thing to do to the heads
Re: what should i get done to the heads
..replace them with ported ls6 heads from SDPC
..then sell the stock units for cash since you don't need to give them back as cores...
The ported LS6 heads from Scoggins Dickie may not be the best for your cam. I think the ports are way large and may not provide the torque you want. Plus I believe that they have like .055 milled so P/V and pushrod length may be an issue. Chamber volume is at 60cc.
I do not know how radical the g5x1 is but I do know that Patriot has some killer prices as well with no core needed. You could either get the 5.3's for the out right CR hike or get some of the LQ9/LS6 heads with any CC you like for any CR without milling.
