looking for info on the Comp #7153 double roller timing chain set
Old 12-06-2008, 04:33 PM
bigfatls6's Avatar
Default looking for info on the Comp #7153 double roller timing chain set
I was just wondering how the clearance is with it when used with a stock cover and 10295 mellings oil pump. I just don't want to have to do to much clearanceing to install it. The 10295 oil pump from what I have heard will have more clearance than the 10296 pump. This will be installed on a 2002 ls1 if that matters.
Old 12-06-2008, 04:51 PM
Sammyboy's Avatar
It comes with spacer plates....there is no clearance issue at all. The only issue that I had was dropping bolt in an oil pan.
Quick Reply: looking for info on the Comp #7153 double roller timing chain set
