1994 trans am manufactured in Canada
Hi everyone, I recently bought a 94 TA that needs a little work. Ive been searching to find info about this year and I cant find a few things so Ive got a couple of Questions. For the 94 production year were all the trans am gt's considered ws6 suspensions? Also my car has a BCM(body control module) which according to Haynes only started in 95, is this info incorrect or does it have to do with it being made in Canada? thanks alot for any info.
Moderator
No WS6 suspension, it isn't like the suspension package on the third gen cars F-cars. For LT1s, WS6 was a suspension package and performance package on the 96-97, often refered to as a ram air car. All the GT package was is an options package, suspension wise they're the same cars be it a GT or non GT optioned car.
Thanks, obviously besides the ram air hood hp increase whats the suspension difference between the ws6 suspension and the standard Trans Am suspension:::::: edit, just found an old thread expaining the differences.
I believe all F platform cars were final assembly in Canada. I forget the plant name.
You need to check the RPO codes if you really want to double check installed options; everything else is just marketing.
run the RPO codes from inside the glove box...
LT1 RPO:
http://performanceworks1.com/LT1%20r...tion_codes.htm
LS1 RPO:
http://performanceworks1.com/LS1%20r...tion_codes.htm
GM RPO:
http://performanceworks1.com/PDF%20F...-car-codes.pdf
LT1 RPO:
LS1 RPO:
GM RPO:
