heads/cam setup question!
Will my ASA 226/236 525/525 110 LSA work with some PRC 2.5 5.3L heads (unmilled/2.04/1.575 valves) without having to flycut? This setup is going on a stock bottom end LS1. What gaskets to use? Need some info asap!!!
Thanks for the help guys. Im actually looking at another cam now. I was going with an MS3 but the heads werent setup for it. I bought them used. So now I need to find a replacement. Any ideas? I don't want to flycut either!!! What about the 228R cam from TSP?
You should contact TSP, They are super friendly and quick to respond.
I am waiting on my 224/236 @ .609/.607 111 cam to come in. Going with the PRC 2.5 5.3 heads also with the larger valves but originally machined for the MS3. I milled the heads 0.020" and TSP "Thought" I should be safe with PTV. But I am going to measure it as soon as my cam shows up, I'll post up my findings when I am able to.
