Will 36 Lb accell injectors be enough for H/C/I and maybe a small dry shot?
Old 12-09-2008, 10:43 AM
bigfatls6's Avatar
Default Will 36 Lb accell injectors be enough for H/C/I and maybe a small dry shot?
I was wondering if a set of accell 36lb injectors would be enough to handle heads, cam and intake with like a 70hp dry shot also? I haven't added the dry shot yet but I might in the future. How do the accell 36 lb compare t othe ford svo 30lb injectors? I know the 30 lb are like a 36 at ls1 fuel pressure. Do the accell injectors rating go up with higher fuel pressure also? I can get a really good deal on the accell is the only reason I haven't bought the 42lb injectors. I just want to make sure the accell 36 lb injectors will be plenty with maybe a little room for a dry shot down the road.
Old 12-09-2008, 11:36 AM
Tom@SpeedInc's Avatar
I would avoid accell injectors, we've had them flow benched, their 42lbs/hr injectors measured 24lbs
would recommend these 36lbs injectors
http://www.speedinc.com/cont.cfm?cid=C0000845
Old 12-09-2008, 06:21 PM
FICINJECTORS's Avatar
Agree totally, Accell are not very good at all, but the Bosch III linked are the ones we swear by.
