which 42 lb injector is better to run in an ls1 Bosch design 2 or 3 ?
I am fixing to order a set of injectors for my H/C/I stock bottom end ls1 that sees mostly street driving and will see a little track use. Which is better the bosch design 2 like the green top injectors or the design 3 blue injector? The design 3 already have the ev1 connection on them.
I decided on the 42 lb injectors because I might add a small dry kit later.
The Bosch Design III's are a more efficient injector with better atomization and spray pattern characteristics. IN MY HUMBLE OPINION, I would not use the 'blue giants' because of the 'V' spray pattern. FICINJECTORS has a fantastic price on the ASA/GTP white 36 lb/hr @ 3 bar Bosch Design III's. These injectors work wonderfully in LSx engines.
