OIL PAN LEAKS!!!!!
Old 09-26-2003, 05:53 AM
DEEZ98Z's Avatar
Default OIL PAN LEAKS!!!!!
A couple months ago I installed whats in my sig.... I was told that I would be safe just to lower my pan and then just tq the bolts back up and it would not leak. WELL IT LEAKS!!!! Does anyone have an idea on what I can do short of replacing the gasket? If not what is the best way to go about changing one and how long does it take??
Old 09-26-2003, 06:10 AM
JRcamaroZ28's Avatar
Default Re: OIL PAN LEAKS!!!!!
well i know for a fact changing the gasket is not fun. you will need to jeck the motor as high as you can get it w/ out the motor mounts conected so you can clear the oil pick up tube going into the pan then you can slid the pan out. its not hard but just a little tight. youll need to drill out 2 pop rivits that hold the gasket on from the factory
JR
