Fueling & Injection - 42 lb injectors too big?
View Full Version : 42 lb injectors too big?
Psychopjv
12-13-2008, 05:00 PM
I have an ls1 will have MTI stage 2r heads at 62cc (being shipped),has a 232/230 .580/.580 110 cam, and will have a 90/90 setup on it. Also plan on spraying a 150 wet shot. I have some FAST 36lbs which are actually 42ish at our rail pressure. Just wondering if this is going to be way too much injector for the car? Thanks.
FICINJECTORS
12-13-2008, 05:50 PM
You should be fine with that setup with a proper tune, they are a little large, but it gives you room in the future.
myfast70
12-13-2008, 06:16 PM
Nope, not at all. I've got 42's on my car and drivability is great. Just be sure to use a good tuner. Most use Nic D. here in Az
