bleader valve size?
Old 12-13-2008, 05:07 PM
PI HAT's Avatar
Arrow bleader valve size?
The brake bleader valves on all four corners of my car are ready to be replaced becasue I stripped a couple. I went to the dealership for replacement bleaders and they said they discontinued them. I went to Advanced Auto Parts and CarQuest and all they have is a bunch of missed matched bleaders in a package on the wall for all vehicle types. The question is how deep is the bleaders supposed to thread. I know they have the hole drilled into the bottom beneath the threads and I figured the length of the bleader would make a diffrence. Im having a hell of a time bleading. I have a mityvac and an attatchment for my air compressor to get the job done.
Old 12-13-2008, 05:25 PM
EchoMirage's Avatar
good question. if you cant find stock, now would be a good time to upgrade to something like a self bleeder. i think earls makes them, both front and rear (theyre different). theyll be matched to your car and should fit perfectly. then bleeding alone will be easy. i dont have them, but others that do say theyre great.
Old 12-19-2008, 07:29 PM
ZexGX's Avatar
Same situation here. My bleeder valves won't come undone and are going to be or are already stripped... What can I do? Mostly, how do I remove them properly?
Old 12-19-2008, 08:55 PM
EchoMirage's Avatar
properly is a 10mm box wrench. if theyre already stripped, vice grips
Old 12-19-2008, 09:42 PM
ZexGX's Avatar
No luck with locking pliers. Tried the 10mm first but it just spun.
Old 12-19-2008, 09:43 PM
LS1-450's Avatar
+1, & if you twist the head off, stick an easy out in her & hope she comes out. Those things (stock bleeders) are a pain in the ***.
Old 12-19-2008, 10:19 PM
shoemike's Avatar
M10 x 1.0
Quick Reply: bleader valve size?
