224/224 Cam in 06 A6 Vette with Video
Old 12-15-2008, 03:37 PM
Tuner@Straightline's Avatar
Default 224/224 Cam in 06 A6 Vette with Video
2006 A6 Corvette, came to us with a 3.15:1 Differential, Melrose Headers, and Callaway Honker CAI. We installed a 224/224 .581/.581 cam. Customer did not want to have to change the converter and wanted a near stock idle. Tuned using our Mustang MD-1100SE dyno.
Baseline pull was:
351rwhp
349rwtq
Final Numbers:
380.1rwhp
355rwhp
I was getting 366rwtq up until the last two pulls. I think the motor was a little heat soaked at that point, showing a only a small gain in torque on the last pull.
Any way here's an over lay of the dyno sheets, and video.
http://www.youtube.com/watch?v=XPU1ZI0z6i0
Attached Thumbnails 224/224 Cam in 06 A6 Vette with Video-roedyno.jpg
Old 12-15-2008, 04:00 PM
XPerformance's Avatar
nice
Old 12-15-2008, 04:25 PM
5_02ls1's Avatar
06 isnt that an ls2???kinda weak...or is the a6 known to rob ALOT of power...
Old 12-15-2008, 07:33 PM
13 Second Truck Club
726.0chevelle's Avatar
what was the lsa on that cam and how does drive without having a stall
Old 12-15-2008, 10:30 PM
The A6's do rob a lot of power. For one the dyno pulls are with the converter unlocked, and second there's no 1:1 transmission ratio. Plus they just take a lot of power to spin.
We see bone stock A6's dyno anywhere from 325-335rwhp, about 20-30rwhp less than manuals which usually dyno between 345-358rwhp bone stock (I did have one do 370 bone stock, but that must have just been a freak).
All those tests are also Mustang Dyno Numbers.
The LSA is a 114 with 2 degrees of advance built in. Car idles at 650rpm, which is only about 75rpm more than stock. It does not push the brakes at all, and for the most part drives like stock aside from slightly more rock at idle.
Old 12-15-2008, 11:38 PM
LSX Mechanic
Damian's Avatar
Guys this is a loaded dyno, not a 1500lb Dynojet.
Nice #'s. Thats a 400rwhp car on a dynojet with a stock idle
Old 12-17-2008, 11:33 AM
dre2013's Avatar
i was disappointed until i saw it was a mustang dyno..not too bad, esp for unlocked numbers
