Coolant Mod Identification
Here are pictures showing the two coolant lines that are supposed to be attached to the corresponding valves by the throttle body as indicated by the arrows. A technician had pointed out to me that these two have been disconnected on mine, and so I was hoping to get an idea of what purpose this modification serves.
Another question I wanted to ask is: Many use the method of detaching the line in the lower picture when filling coolant into the radiator to get out most of the air, since this line is the highest point of the cooling system. Once coolant starts to drip out from that line, then they reconnect it, leaving little to no air inside. So for someone who has this line disconnected from a system modification, what is the next best method for minimizing air in the coolant?
Any input is greatly appreciated.
Happy Holidays.
Is the line just plugged off and the nipple on the radiator capped? If so you need to run a hose from the coolant bleed to the radiator. It's a common mod for people to bypass the throttle body to prevent it from heating the incoming air, but just plugging the line off at the heads isn't good.
The line under the radiator cap extends further down but has a bolt-like object sealing it as a dead end. I would say it's got about a foot length hanging there.
So for a throttle body bypass, it's safe to just reattach the hoses? Should I try to get out any dirt and residue from the exposed valves first?
Just out of curiosity, what's the worst that could happen when you run the vehicle with this kind of bypass?
