rear end swap
Old 12-20-2008, 12:46 PM
duckvader's Avatar
Default rear end swap
will a rearend from a 2000 formula fit a 1995 camaro? is there a difference in brakes? thanks will
Old 12-20-2008, 01:07 PM
the_merv's Avatar
There is a difference in the Brakes, I think you may have to pull the Axles, because I think the Caliper Brackets are different as well.
Old 12-20-2008, 09:05 PM
BadBandit69's Avatar
the brakes are different but they should work fine in your older car(better actually). The only real problem i see is if your new rearend is a 4channel(sensors out on the ends with the brakes). I think lt1 cars all had 3channels(1 sensor on top of the center section). You don't have to have a 3 channel for it work but you will lose you ABS and you will get a light on the dash for it.
Old 01-19-2009, 01:01 PM
AChotrod's Avatar
I have a 10bolt with 3.42s for sale if ya need one. Its out of my 96 Ws6 formula on 32,000 miles and in great shape!!!
