what wheel/tire setup for track
My 99 formulas been geeting more and more power and mods. I haven't taken it to the track since it was a cai/cat back only car.
When I get it back from the engine builder it will have over 400rwhp and I dont know how much tire or what wheel to use. I have nice wheels and tires to drive around on and anything else would be swapped for that visit to the track only.
Can I get away with a cheap 16x8 salad shooter and drag radial combo. Or should I get like a summit star 15x10 and slicks and grind my calipers.
The car is stalled and has all of the suspension done and I don't want things to get hairy going down the 1/4. So give me your feed back, suggestions, and opinions thanks in advance.
PS I'm not going to have much $$$ when its done either so anything on the cheaper side would help more.
i would go with a billet spec. 15x10 w/7.5 bs and front 15x3.5 they clear your calipers with very min grinding if any....and then a m/t dr's but thats me , you can get away with some 255/50/16 m/t drs on some 16's just to get by.
the summits would be the cheapest way to go
In your position I would just buy a set of m/t drag radials and put them on your salad shooters that will easily hold your power with the proper burnout there is cars that run 8's on a 8" slick
