STS Question for LS1 Swap Into a Truck
Old 12-24-2008, 03:01 PM
exodus's Avatar
Default STS Question for LS1 Swap Into a Truck
Hope this belongs here in the FI section. Wasn't sure if it should have been here or the Hybrid section.
The Question that I have is:
I want to install an STS kit on my 97 Z71. The kicker is the engine is going to be out of my 98 Z28 with some minor bolton's (and rod bolts, LOL), and will be running a FLP 4L80E trans. So should I try and make the universal kit (w/ t-76), or should I try and get the f-body, or truck kit to work? I was thinking of trying the 99 and up truck/suv kit since the body is similar, but I am not sure. If there is a member from STS on the board, I hope you read this. The last thing that I want is to spend the money on the wrong setup. I also thought of making my own, but I have never fabed up a turbo kit, and want it to be right.
Any and all info is apreciated, Thanks!
Old 12-24-2008, 04:43 PM
shawn_c992001's Avatar
Send a PM to "boosted in the rear" his name is Chris Martinez and he works for STS if you call STS his extension is 803.
Old 12-24-2008, 04:48 PM
exodus's Avatar
Thanks, probably will after the holiday
