rear end ?
Old 12-24-2008, 03:26 PM
TravisMcGill2000's Avatar
Default rear end ?
will a m6 3.42 center section fit in a 2.73 a4.are the axles the same.thanks
Old 12-24-2008, 03:34 PM
Elliott's94Z's Avatar
I don't believe it will man.....
Old 12-24-2008, 03:38 PM
damn 10 bolts... looks like im goin to have to break down and buy a 9in
Old 12-24-2008, 03:39 PM
Formula350's Avatar
Yes, the carrier + Ring and Pinion will all fit from 82-02 models (however there might be an axle spline difference so stick with 93-02). The posi unit will NOT work with your 2.73s though, you'd need the little adapter-spacer ring-a-mabob .
Old 12-24-2008, 03:47 PM
i want to change the carrier and to a 3.42 gear.
Old 12-24-2008, 03:56 PM
Formula350's Avatar
Will work just fine, make sure you get the pinion gear too. Not sure what kind of driving you do, but if you don't do a ton of track time, the 99+ rears use Torsen posi. I prefer it over the clutch style, but according to people on here they don't hold up as well if you do a ton of drag racing. The one benefit though is that since it's newer, it'll have less miles
