Fuel Pressure Problems
Just installed my holley fuel pressure regulator on my LT1 a few weeks ago. Also, yesterday i wanted to test my new fuel pressure tester. Hooked it up to the schrader valve, primed the pump, and:
Needle went to about 20psi, then dropped back to zero as soon as the pump shut off. Same result after two more primes.
Once i got the car running, i have about 23psi.
Supposidly, fuel pump is new walbro 255. Im thinking fuel filter (which im going to do anyways). Could it be the regulator? Its brand new.
