Need some help picking out a cam!!!
Old 12-25-2008, 06:21 PM
305 h.o.'s Avatar
Default Need some help picking out a cam!!!
Any good sites, I looked on summitracing.com and cant find nothing under a 500 lift cam. Im looking for around 447 lift or 430 lift due to the fact that I have 1.6' roller rockers. So any ideas?
Old 12-25-2008, 06:53 PM
2XR95Z28's Avatar
I would take a look at the cam thread at the top of the LT1 section that is a real good start for looking. I myself am going with an Advanced Induction set-up i have heard nothing but good things so i can't wait to get the cam on monday, check them out at www.advancedinductions.com there are alot of choices so i would check out the cam thread and AI's website.
Old 12-25-2008, 06:58 PM
96lt1m6's Avatar
which car is this cam for.
if it's for the 3rd gen i would get the comp cams 12-404-4 its 444 lift so add the 1.6s and you should have roughly 476
Old 12-25-2008, 07:19 PM
Bersaglieri's Avatar
You probably cant find one since that's about the lift your stock cam has with 1.6 rockers. For the sake of arguement I wouldnt waste my time swapping a cam out unless it was worth it. Matter of fact off the top of my head .447/.430 is smaller than your stock cam.
-Dustin-
Old 12-25-2008, 08:35 PM
want297z's Avatar
218/230-114 Comp Cams "Extreme" LT1 Camshaft, 218 / 230, .495 / .510 114 LSA, Agressive camshaft for street/strip blower applications. Computer tuning required.
This is the cam I run on my stock bottom end LT1 with 1.6 rockers. Used to be called the Randy cam for those who have been around for a long time. Just change the springs out and good to go.
Old 12-25-2008, 10:15 PM
LM97Z's Avatar
http://www.elliottsportworks.com/lt1.html
