what short torque arm to use with true duals
I have an A4 395ls6 in a 98 trans am. I am planning on running a gear vendors overdrive unit on the trans so that will require me to run a short torque arm since the space is occupied by the gearvendors unit. The only problem is that I have true duals and would like to keep them. Other than the Jegster/GMS torque arm are there any other short torque arms out there that I can run true duals with that don't bolt to the trans tunnel?
I have the Jegster and it really went in alot quicker than I thought it would. I didnt clear out the whole interior just took the center console out and that was good enough. No noise and seems to work great.
My car is currently equiped with the Jegster torque arm on my other car. I was just wondering if BMR or any other big name companies have a set up that could work better. I really dont like the fact that you have to drill into the trans tunnel several times. thanks for the help.
LS1Tech Premium Sponsor
i offer a tunnel mounted torque arm specifically for the true duals on the 93-02 f body. chromemoly adjustable torque arm with adjustable height pivot link. pivot link is poly bushed at the crossmember for noise-free operation. bolt-in setup... no drilling required.
