headlight failure
Old 12-28-2008, 10:11 AM
Kmaroman's Avatar
Default headlight failure
My low beam headlights are being gay lately. I guess its my fault because i assumed when only the driverside went out it was a light, there went 25bucks. Well i put the new headlight in an it doesn't work, I looked at the wire inside both headlights an they where fine. Is this a common problem, could the wires running to the light be grounding out. I'm going to find my tester light light later. Why would only the driverside light go out, are both headlights on the same wire. Just any input at all would help alot as I'm clueless??
Old 12-28-2008, 02:38 PM
Kmaroman's Avatar
bump bump
Old 12-28-2008, 02:52 PM
MonmouthCtyLS7's Avatar
Ive had headlight problems in 2 outta 4 4th gens ive owned...Not sure if its a common problem though. One of my fog lights are out right now on my ls1 swap car
Old 01-01-2009, 10:41 PM
SoccerStudd101's Avatar
I have a similar problem. Only the brights work. No fog lights either, checked all the bulbs and they are good. Haven't really looked into it much other than that. Sooner or later I will though.
Old 01-02-2009, 02:26 PM
Formula350's Avatar
Most likely your headlight switch inside the car.
