high idle
Old 12-28-2008, 07:27 PM
95firebird5.7's Avatar
Default high idle
in park the car idles at 2k but when i put into drive it idles fine. i looked for vacuum leaks didnt find one. also cleaned the tb didnt help what else coud cause this thanks
Old 12-28-2008, 10:40 PM
JeremyB's Avatar
is it only when its cold or does it do it all the time?
it does it when its cold to heat up the engine faster
if its all the time, i would think its a vacuum leak, not much of one, but since you said its not leaking, then im not sure what else it could be
Old 12-28-2008, 10:42 PM
it does it all the time. ill look again for a vacuum leak
Old 12-28-2008, 10:46 PM
jsteele90's Avatar
does your throttle blade close all the way
Old 12-28-2008, 10:54 PM
yes it does
Old 12-28-2008, 11:40 PM
stephen p's Avatar
just went through this.. change the tps, and live happily ever after
Old 12-28-2008, 11:44 PM
lol how much was that?
Old 12-28-2008, 11:47 PM
jsteele90's Avatar
30 bucks at autozone.
