00-02 exhaust manifolds on a 1999
If you install the newer exhaust manifolds on a 99 is the egr parts the same? I'm thinking of going to the newer manifolds and Y pipe on my STS set up.
I was planning on buying a ORY and thought I might as well buy the ORY for the newer manifolds and do a swap. I'm going to have the ORY and manifolds ceramic coated.
The newer manifolds are supposed to be better, I'm thinking that if I go through all the trouble to buy a ORY, remove my stock manifolds to have them ceramic coated I might as well look into swapping to the better manifolds.
