question about pcv + oil leak
Old 12-31-2008, 03:33 PM
lowerthanyou00's Avatar
Default question about pcv + oil leak
well my 2k camaro has developed a oil leak recently. First thing i thought of was pcv clogged causing oil to blow out the rear main, pulled it out but it was not, anyways i decided to pull out all the pcv piping and i discovered the "y" in the back behind the manifold was broken in two. Would this be sufficient to cause a oil leak from the main? Also it is not leaking oil from pcv lines or anything else topside of the engine.
