axel bearing replacement
Old 01-01-2009, 08:25 AM
yeller_xtc's Avatar
Question axel bearing replacement
i know how to slide the axel out. how do i get the axel bearings out? do i grease them before reinstalling them? any tip will be helpful!
Old 01-01-2009, 09:42 AM
BigZee71's Avatar
I believe the bearing is held in place by the axle/ seal and it should just come out
once the axle is out of the way. When you remove the c-clips and calipers it should just fall apart. You dont have to pack them, they use the rear end oil.
Old 01-01-2009, 10:44 AM
Atver300's Avatar
Not exactly that easy you will need to remove the bearings with a slide hammer, and save the old races to use to beat the new bearings in. put light grease on them for new instalation
Old 01-01-2009, 11:14 AM
yeller_xtc's Avatar
thanks guys!
Old 01-02-2009, 05:53 PM
waynehartwig's Avatar
Agreed! That grease is important as there won't be any diff fluid out there for a while after they get replaced... Put some on the seal and the backside of the seal to cover up the spring - keep the spring from coming off when you put the new seal in.
If you have the diff out, you can use a long drift or ? and beat it out from the other side a lot easier. Sometimes the slide hammer will get them cawked sideways and make them more difficult to get out. Sometimes a little nudge in will break them loose and allow you to pull them out easier.
