ayousef
01-04-2009, 04:17 PM
Does anyone use an external fuel pump triggered via boost?
I can trigger my pump to kick in at 2PSI, stock pump WILL most definitely run out at 4.5PSI.
Wondering if I will have any fuel starvation issues till the secondary pump kicks in, given that boost build-up on the twin turbo set-up will be LIGHTING fast.
As a remedy, I thought of wiring an MSD window switch at 3000RPMs, is this necessary?
Thanks.
Thanks.
