head studs or bolts
head studs or bolts
im going to be spraying my 402 with about a 150 shot maybe a 200shot down the road. i bought arp head bolts. the question is,should i return them to summit and buy head studs? or will it be ok.
I went studs. Glad I did since I had to tear mine down recently, don't need to worry about dyring out the bolt holes now (of course I also need to get a new block, but that is beside the point).
...if you plan to take your heads off more than once, I recommend studs all the way...you'll definitely appreciate them ....I've stripped more bolts than I care to remember...studs are definitely worth the extra $100 ....
