complete system for sale or trade for parts
HEADUNIT SONY CDX-F7710
Features:
Full Motion FL Display
High-Resolution Graphics
CD / MP3 Playback
ID3 Tag and CD-Text Display
ATRAC3™ Plus / Connect™ Music Store Ready
Scrolling Titles with Auto Scroll
Album / Disc Repeat & Shuffle
BBE MP Digital Sound Restoration
Detachable Fold-Down Face
Aluminum Faceplate Finish
Dynamics Soundstage Organizer (DSO)
EQ7 7-Band Equalizer
1-Bit D/A Converter
Active Servo Control
45-Degree Install Capability
4-Volt Front & Rear Preamp Outputs with Selectable High-Pass Filters
4-Volt Subwoofer Preamp Output with Selectable Low-Pass Filter
Rear Auxiliary Input
XM Tuner Ready
CD / MD Changer Control
SSIR-EXA Tuner
18FM + 12AM Presets
Station Memo (radio preset naming) and Custom File (disc naming)
52W x 4 (max) S-MOSFET Power IC
Drive-S Chassis with 100+ dB Signal-To-Noise (S/N) Ratio
Clock
AMP KENWOOD-7202
FEATURES:
RMS Power Output (Watts x Channels) 150 x 2
Frequency Response 20-20k Hz
THD at Rated RMS Power 1%
Signal to Noise Ratio 100 dB
Input Voltage 14.4v
Peak Power Output (Watts x Channels) 460 x 2
Power at 2 Ohms (Watts x Channels) 230 x 2
Bridged Power (Watts x Channels) 460 x 1
Minimum Impedance Bridged 4
Minimum Impedance Unbridged 2
Amplifier Class AB
Tri-Way Capable Yes
Low-Pass Crossover Frequency 50-200 Hz
Low-Pass Slope (dB/octave) 24 dB
High-Pass Crossover Frequency 50-200 Hz
High-Pass Slope (dB/octave) 12 dB
Bass Boost 0-18 dB
Bass Boost Frequency 40 Hz
Fan Cooled Yes
Fuse Rating 40 x 1
Speaker Level Inputs Yes
Preamp Outputs 1 pair
LED Power Indicator Yes
Height (inches) 2-7/16
Width (inches) 15
Length (inches) 11-5/16
POWERING 2-12" PIONEER SUBS IN A CARPETED PREFABED BOX THAT FITS A 93-02 TRANSAM OR CAMARO but will also fit in some trunks
asking 500 for everything. it is currently all in the car still. if you want to listen to it before you buy it just call 724-612-3373
id like to partial trade for a 6 or 8 point roll cage or subframe connectors.
Features:
CD / MP3 Playback
1-Bit D/A Converter
XM Tuner Ready
SSIR-EXA Tuner
18FM + 12AM Presets
Clock
AMP KENWOOD-7202
FEATURES:
Input Voltage 14.4v
Amplifier Class AB
Tri-Way Capable Yes
Bass Boost 0-18 dB
Fan Cooled Yes
Fuse Rating 40 x 1
Width (inches) 15
