3.8 to ls1 swap on a 99 firebird i have a few problems!!!
Old 01-07-2009, 02:08 PM
mustanglogan88's Avatar
Default 3.8 to ls1 swap on a 99 firebird i have a few problems!!!
first of all let me apologize for the name... i am a ford guy trying to build a trans am for a friend. well i have everything absolutely in the car. the motor swap went smooth. i have replaced the fuel pump, radiator, transmission, and the entire wiring harness and the computer. The problem i am having is that the car will not start. when i turn the key over the fuel pump primes then as soon as i crank the car the pump shuts off. i have used a voltage meter to test at the fuel pump to see if it has voltage when i try to crank it. none at all. it goes from 11.25-11.55v while it is priming then when the motor turns over it stops receiving voltage. is there anything you guys would suggest trying to figure out this problem.
Old 01-07-2009, 04:27 PM
Tech Fanatic
yellowbird1232's Avatar
vats relearn
Old 01-10-2009, 09:49 PM
Originally Posted by yellowbird1232
vats relearn
so how do i do that? i have heard of vats bypass modules, but i have no idea of how to i guess reprogram the vats system.
Old 01-11-2009, 08:45 AM
01 BERGER CAMARO SS's Avatar
my car did this alot and i turned the key forward. I turned off the ac. radio and rolled down the windows all the way. I turned it of and turned it back on to the on positions and let it sit for 30-40 min. Then turned her off and back on an it worked.
