WTT AFR 205 66cc for AFR 225
I have a set of afr 205 66cc heads that are under 3 months old. Replaced old heads on motor due to bent valves so went with these. I had already decided to do a new motor this winter and use the same heads but in the process went a lil bit wilder than i expected. Need a set of 225's with 66cc or greater. Just throwing this out hoping maybe someone did what i did in reverse and got bigger heads than they need. Thanks
