Mismatched heads???
Old 01-09-2009, 11:43 AM
shaguar_red's Avatar
Default Mismatched heads???
My buddy and I pulled apart the engine from his 1995 Formula and found the heads had two different casting numbers. One is 10128374 and the other is 10207643. We are going to have them resurfaced and mildly ported, but could this have caused problems with his formulas performance? And is it ok to go ahead and use the mismatched heads as long as we get them machined and port matched? Thanks guys.
Old 01-09-2009, 05:33 PM
fuel's Avatar
my porter told me my heads had diffrent casting #s. but still mad 420 to the ground
Old 01-14-2009, 09:01 AM
hmm. anyone else had this experience?
Old 01-14-2009, 09:29 AM
ss.slp.ls1's Avatar
They are both LT1 alum heads and should be pretty much identical. Once ported, any casting differences, if any, will probably be non-existent.
Old 01-14-2009, 10:16 AM
SpeedDensityZ's Avatar
Agreed!! And it helps that they are both the casting numbers porters want to use. So, there is plenty of material to be removed.
Old 01-16-2009, 11:55 AM
94Z28rag's Avatar
Not true at all: http://www.camaroz28.com/forums/showthread.php?t=427346
374 and 643 are the "good" casting numbers, whereas the later years, 96-97 got lighter, slightly different heads from the factory and these are much less ideal for porting.
OP, both of your heads are good!
Quick Reply: Mismatched heads???
