What heads/cam package with my mods
i was looking on tsp today and i was looking at the heads cam packages
i dont know if i should do the stg 1 ls1 heads and a ms3 cam or the stg 2.5 5.3L heads and ms3
i want the ms3 but dont know what heads to get any info will help
thanks
Mike
here are links
http://www.texas-speed.com/shop/item...d=680&catid=47
http://www.texas-speed.com/shop/item...d=203&catid=47
thanks
Mike
here are links
LS1Tech Premium Sponsor
Give us a call & we can discuss combos & what we've engine dyno tested. I think we can help you pick a good combo. The MS3 will clear 5.3l stage 2.5 heads as long as we configure them with minimal milling & a certain valve setup. We are also about to have the new PRC 215 heads ready that should push a well setup MS cam car near 500rwhp with supporting mods. A independent shop recently made near 500rwhp with a Tsunami camshaft & the PRC 215 heads!!
Personally I'd run something like the Tsunami 235/240 & the PRC 2.5 5.3l heads if your on a budget. If your looking for 500rwhp then I'd go Tsunami or MS4 with the PRC 215s & thinner gaskets!
http://www.texas-speed.com/shop/item...d=993&catid=40
http://www.texas-speed.com/shop/item...id=84&catid=40
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
deff will give u a call soon
had the money but sadly spun out and hit a tree gotta fix that first
but i want 500rwhp be badass lol
is that ok its gunna be my dd to work whats a good stall for that or the ms3? 3600?
