LS6 donor into my 98 six speed
I may be picking up a ls6 motor out of a wrecked ZO6. It would cost me $800 for the complete motor. I don't yet have the details as to the specific year the motor is out of but I assume it is a 02. How involved is this swap. I know that I would need an F-body intake but what about the computer. Can I send my 98 CPU out for programming or do I need a newer model. Also, what are complete LS1 motors going for these days?
Re: LS6 donor into my 98 six speed
...there aren't any VINs on engine blocks anymore; right?...
Everything should bolt right up....the engine oil pan in a F-body and Vette are different, however...so is the throttle body...just use the f-body stuff...
F-body computer should work OK...
While your at it, swap the cam and springs...
I know the price is low, I have a buddy that works in a salvage yard and he gets an employee discount on all parts. So, I need to switch the oil pan as well as the intake and throttle body. I thought about doing a cam if I can get enough for my complete motor. We'll see.
LS1Tech Co-Founder
Adrian, you need to switch:
oil pain
throttle setup
all the brackets
If you put it in it will run no problem but you may want to dyno it and optimize the power.
$800 for a complete longlock S06 is a super deal.
You could also try to flip it and make about $3000 on it.
oil pain
throttle setup
all the brackets
