radio/window problem
Old 01-15-2009, 08:46 PM
BLULS1Z28's Avatar
Default radio/window problem
i have a alpine radio works great but randomly it shuts off and the windows wont work wile its shut off. i turns back on randomly and everything is fine.i think its a ground but does the windows and radio share a comon groud?if so where is it located?
Old 01-16-2009, 09:41 AM
Ungrounded Moderator
WhiteBird00's Avatar
It's not a ground - it's your retained accessory power (RAP) circuit which is controlled by the Body Control Module (BCM). The problem may be caused by a loose wire at the BCM or by a broken solder joint inside the BCM.
There is more information in this thread. (The original poster got pissed off for some reason and deleted the post but it is quoted a few posts further down.)
