New Heads being toredown?
Old 01-16-2009, 06:22 PM
94m6Z28's Avatar
Default New Heads being toredown?
is it common when a shop builds a motor useing out of the box heads, for them to tear them down and check spring pressure and guild clearince and all that? or is it all b.s
say on a set of AFR comp heads
Old 01-16-2009, 06:32 PM
Ken95Z28's Avatar
If they are building the motor and you supplied the heads I would say yes. They want to make sure that the springs are good and everything is aligned properly. I would say if they built the heads up themselves at least they know it was done properly. I guess they feel better if they checked it out then just slapping them on the motor. I know I would feel better as well.
Old 01-16-2009, 07:06 PM
myltwon's Avatar
if I were a shop that wanted to stand behind my work, I'd double check all parts supplied by the customer
last thing he'd want would be a valve dropping and trashing the motor due to parts supplied and his name getting slandered locally and on the internet. that type of thing happens waaaay too often
Quick Reply: New Heads being toredown?
